Отремонтируйте ваше устройство
Обучение ремонту
Запчасти и инструменты
Видео обзор
Введение
For iFixit's official Galaxy S6 teardown, click here. The guide you are currently viewing is retained for historical purposes only.
Это демонтаж а неруководство по ремонту. Чтобы отремонтировать Samsung Galaxy S6, воспользуйтесь нашим сервисным руководством.
  1. Power off the Samsung Galaxy S6.
    • Power off the Samsung Galaxy S6.
    • Use an eject pin or pointed tweezers to take out the SIM Card Tray.
  2. Heat up the Samsung Galaxy S6 Battery Door.
    • Heat up the Samsung Galaxy S6 Battery Door.
    • Draw the battery cover up with a suction cup. (Note: The battery door is adhered to the rear housing with quite strong adhesive, take your time during this process.)
    • Separate the battery door with an opening pick.
  3. Undo the 13 screws in the rear housing. Heat up the LCD Assembly.
    • Undo the 13 screws in the rear housing.
    • Heat up the LCD Assembly.
    • Separate the rear housing from the LCD Assembly with the help of suction cup tool and case opening tool. (Notice: be careful not to damage the wireless charging chip attached to the battery.)
  4. Remove the power button flex. Remove the volume button flex. Remove the side keys. (Note: the Galaxy S6 power button and volume buttons are compatible with each other.)
    • Remove the power button flex.
    • Remove the volume button flex.
    • Remove the side keys. (Note: the Galaxy S6 power button and volume buttons are compatible with each other.)
  5. LCD iPhone Screen Fix Kits
    The budget option, covered by our Lifetime Warranty.
    Shop Kits
    Cut repair costs, not quality.
    Shop Kits
  6. Pry up the charging chip flex ribbons on both sides of rear housing. (Notice: be careful not to damage the flex ribbons.)
    • Pry up the charging chip flex ribbons on both sides of rear housing. (Notice: be careful not to damage the flex ribbons.)
  7. Pry up the LCD assembly connector, front facing camera connector, battery connector, ear speaker connector and home button flex ribbon connector.
    • Pry up the LCD assembly connector, front facing camera connector, battery connector, ear speaker connector and home button flex ribbon connector.
    • Turn over the motherboard and pry up the connector.
  8. Gently pry up the battery with a spudger.
    • Gently pry up the battery with a spudger.
  9. Remove the front facing camera. Remove the ear speaker. (Notice: be careful not to break the flex ribbon.) Remove the vibrating motor.
    • Remove the front facing camera.
    • Remove the ear speaker. (Notice: be careful not to break the flex ribbon.)
    • Remove the vibrating motor.
  10. Remove the back facing camera on the mainboard. Remove the Bluetooth cable and Wi-Fi signal cable.
    • Remove the back facing camera on the mainboard.
    • Remove the Bluetooth cable and Wi-Fi signal cable.
  11. Undo the earphone jack screw. (Notice: the screw is different than the rear housing screws.) Heat up the LCD Assembly to release the front housing. Pry up the navigation light stickers.
    • Undo the earphone jack screw. (Notice: the screw is different than the rear housing screws.)
    • Heat up the LCD Assembly to release the front housing.
    • Pry up the navigation light stickers.
  12. Pry up the connector on the back side of home button.
    • Pry up the connector on the back side of home button.
    • Pry up the home button.
  13. The Samsung Galaxy S6 disassembly process is complete.
    • The Samsung Galaxy S6 disassembly process is complete.
Mandy
Участник с: 05.12.2014
9 017 Репутация
Автор 9 руководств
Комментариев: 20
Thanks man i was curious what's inside that puppy... Not an easy repair like my galaxy s3....
Tear down s6 edge please
Mateusz - Ответить
I'm curious, what is the DAC on this phone? I know Cirrus Logic partnered with Wolfson so it could be interesting to find out.
Mike Vercimak - Ответить
The original author of this guide is ETrade Supply (as noted by the video itself). The video, images, and writeup were all produced and watermarked by them, though the image watermarks have since been removed via liberal cropping.
For the full and un-doctored photo set, please see:
http://www.etradesupply.com/blog/how-to-...
Chris Gilliam - Ответить
Which image sensor did Samsung use for GS6? Is it SONY?
Will - Ответить
Where is the memory located? And is it possible to upgrade it?
chris - Ответить
Добавить комментарий
Просмотр статистики:
За последние 24часов: 9
За последние 7 дней: 30
За последние 30 дней: 108
За всё время: 138,337
