Введение
This is a teardown of the Samsung SCH-8500.
This teardown is not a repair guide. To repair your Samsung SCH-8500, use our service manual.
  1. The phone we are taking apart today is the Samsung SCH-8500 The phone we are taking apart today is the Samsung SCH-8500 The phone we are taking apart today is the Samsung SCH-8500
    • The phone we are taking apart today is the Samsung SCH-8500
  2. Press on black button next to battery and use metal spuger or other pointy object to pop the battery of the back. Press on black button next to battery and use metal spuger or other pointy object to pop the battery of the back. Press on black button next to battery and use metal spuger or other pointy object to pop the battery of the back.
    • Press on black button next to battery and use metal spuger or other pointy object to pop the battery of the back.
  3. Remove 4 0.6mm screws with a T6 Screwdriver. Remove 4 0.6mm screws with a T6 Screwdriver. Remove 4 0.6mm screws with a T6 Screwdriver.
    • Remove 4 0.6mm screws with a T6 Screwdriver.
  4. Remove the little rubber piece. Then gently lift off back case. Then gently lift off back case.
    • Remove the little rubber piece.
    • Then gently lift off back case.
  5. Free shipping on all orders over 100 $ or containing a Pro Tech Toolkit!
    Посмотрите наш магазин
  6. Unscrew the antenna from back case. Unscrew the antenna from back case. Unscrew the antenna from back case.
    • Unscrew the antenna from back case.
  7. Pry off the 2 covers on the display. Pry off the 2 covers on the display. Pry off the 2 covers on the display.
    • Pry off the 2 covers on the display.
  8. Remove the 2 0.3mm screws from display Remove the 2 0.3mm screws from display Remove the 2 0.3mm screws from display
    • Remove the 2 0.3mm screws from display
  9. Pry the speaker cover off display, to reveal 2 screws. Pry the speaker cover off display, to reveal 2 screws. Pry the speaker cover off display, to reveal 2 screws.
    • Pry the speaker cover off display, to reveal 2 screws.
  10. Remove 2 0.3mm screws. Remove 2 0.3mm screws. Remove 2 0.3mm screws.
    • Remove 2 0.3mm screws.
  11. Use a case opening tool and pry the case of the display. Use a case opening tool and pry the case of the display.
    • Use a case opening tool and pry the case of the display.
  12. Pry the display, speakers, and main board of of phone Take off the keys Take off the keys
    • Pry the display, speakers, and main board of of phone
    • Take off the keys
  13. Voila! You're done.
    • Voila! You're done.
William Maddrey
Участник с: 13.03.2013
131 Репутация
1 Guide authored
Комментариев: 0
Просмотр статистики:
За 24 часа: 0
За 7 дней: 0
За 30 дней: 1
За всё время: 586
