Выберете то, что вам нужно
Insert yout flathead screwdriver or opening here and go around the device
Gently pry open the case.
Once the case is removed you can see the PCB.
NXP OM6357EL4 ARM CPU
SPANSION Flash Memory
NXP CF50600 battery and power supply controller
SIM Card slot
EMI Shield
Battery Contacts
To get the other side of the PCB, pull up the edges of the PCB with a flathead screwdriver.
To remove the EMI shield on the other side, remove these screws
