This teardown is not a repair guide. To repair your Samsung SGH-C450, use our service manual.
  1. Remove the battery cover, battery and SIM Card.
    • Remove the battery cover, battery and SIM Card.
  2. Remove these screws.
    • Remove these screws.
  3. Insert yout flathead screwdriver or opening here and go around the device
    • Insert yout flathead screwdriver or opening here and go around the device
    • Gently pry open the case.
  4. Skip the upgrade.
    Take $10 off $50 with
    SKIPANDSAVE10
    Save Now
    Skip the upgrade.
    SKIPANDSAVE10
    Save Now
  5. Once the case is removed you can see the PCB.
    • Once the case is removed you can see the PCB.
    • NXP OM6357EL4 ARM CPU
    • SPANSION Flash Memory
    • NXP CF50600 battery and power supply controller
    • SIM Card slot
    • EMI Shield
    • Battery Contacts
  6. To get the other side of the PCB, pull up the edges of the PCB with a flathead screwdriver.
    • To get the other side of the PCB, pull up the edges of the PCB with a flathead screwdriver.
    • To remove the EMI shield on the other side, remove these screws
  7. The IC's under the EMI shield.
    • The IC's under the EMI shield.
    • Skyworks SKY77518 Dual-Band GSM/GPRS Module
  8. Finished!
    • Finished!
Bryan
Участник с: 27.10.2012
690 Репутация
Автор 5 руководств
Комментариев: 0
Добавить комментарий
Просмотр статистики:
За 24 часа: 0
За 7 дней: 0
За 30 дней: 0
За всё время: 1,502
