Введение
A simple guide on safe disassembly of your Samsung Wireless Charging Pad.
Выберете то, что вам нужно
Do not remove the rubber ring on top, the adhesive may weaken (alike mine, which barely sticks on) when you attempt to replace it.
Flip your Wireless Charging Pad over, noting the position of the Qi logo (Bottom right of label)
Use your Jimmy tool to pry in between the two clear plastic layers. Try to keep the Jimmy's tip pointed upwards as you push it into the Charging pad, and the rounded side down (Relative to the Qi logo).
Now slide the jimmy up gently until it stops.
Инструмент, используемый на этом этапе:Tweezers$4.99
Without removing the Jimmy tool, rotate the top (still upside down) clockwise, and the bottom counter clockwise. The two pieces will separate from each other.
Remove the four marked screws from their holes with your small screwdriver...
...Making sure that you place them in a screw tray or safe place of sorts until you are ready to reassemble the Charging Pad.
Gently separate the two pieces. Here you will find the powerboard.
Reverse these steps to reassemble the Charging Pad, and plug the pad in upon completion to test the functionality. Congrats, you've successfully disassembled the Samsung Wireless Charging Pad
