Отремонтируйте ваше устройство
Обучение ремонту
Магазин
Введение
Follow the steps in this guide in order to gain access to components found inside the device which most often require repair of replacement.
Это демонтаж а неруководство по ремонту. Чтобы отремонтировать Sandisk Sansa m230 Series mp3 player, воспользуйтесь нашим сервисным руководством.
  1. Remove the battery compartment cover.
    • Remove the battery compartment cover.
    • Remove the battery.
  2. Locate and remove the screw next to the battery compartment lid.
    • Locate and remove the screw next to the battery compartment lid.
  3. The Essential Toolkit
    The most helpful tools in our most compact kit.
    Купить сейчас
    Купить сейчас
  4. Locate the interlocking pegs along the seam of the device's casings.
    • Locate the interlocking pegs along the seam of the device's casings.
    • Gently pry the pegs apart one at a time, working your way around the case.
    • Be careful when prying apart the pegs: they are made of plastic and may break.
  5. The battery contact springs may prevent the case from separating.
    • The battery contact springs may prevent the case from separating.
    • Push the battery contact springs down through the hole in the case.
  6. The casing protecting the USB and headphone jacks must be removed.
    • The casing protecting the USB and headphone jacks must be removed.
    • Locate and gently pry apart the two interlocking clips holding it in place.
    • The outer casings may now be removed and the MP3 player should separate.
  7. You now have access to all components found on the inside of the device!
    • You now have access to all components found on the inside of the device!
James Thorne
Участник с: 05.11.2013
638 Репутация
Автор 6 руководств
Команда
UMass Dartmouth, Team 1-8, Shastany Fall 2013 Участник UMass Dartmouth, Team 1-8, Shastany Fall 2013
UMASSD-SHASTANY-F13S1G8
3 членов
Автор 6 руководств
Комментариев: 0
Добавить комментарий
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 1
За последние 30 дней: 8
За всё время: 2,318
