Инструменты для этого Разбора
Введение
We disassembled this calculator on April 17, 2010.
This teardown is not a repair guide. To repair your Sanyo CX 110, use our service manual.
    • Here is the Sanyo CX 110 calculator.
    • Remove these two screws from the back of the calculator using a Phillips #0 Screwdriver.
  1. Now that we removed the back of the calculator, here is the battery and the back of the logic board. Sanyo Tight-Seal Power-Up Sum-3 1.5V AA battery.
    • Now that we removed the back of the calculator, here is the battery and the back of the logic board.
    • Sanyo Tight-Seal Power-Up Sum-3 1.5V AA battery.
    • Positive contact for the battery.
    • Negative contact for the battery.
  2. Комплект инструментов для замены батареи Macbook
    Доступно с $69.99
    Buy Now
    Доступно с $69.99
    Buy Now
  3. Remove these 7 screws using a razor blade.
    • Remove these 7 screws using a razor blade.
    • Be careful not to break the razor blade because it is fragile.
    • Turn the circuit board 180 degrees after removing screws.
  4. You will now see the circuit board and the buttons. Remove the buttons for the calculator. You will now see the circuit board and the buttons. Remove the buttons for the calculator.
    • You will now see the circuit board and the buttons. Remove the buttons for the calculator.
  5. Now we're all done! Just take the LCD apart and you are done completely!
    • Now we're all done! Just take the LCD apart and you are done completely!
    • Sum-3 Sanyo Battery.
    • LCD Screen Parts (darkener, inverter, LCD screen.
    • Circuit Board for the calculator.
    • Buttons for the calculator (square root, memory, percent, operators, numbers, etc.)
    • Housing for the calculator.
samhnri
Участник с: 07.04.2010
417 Репутация
Автор 2 руководств
Комментариев: 0
Добавить комментарий
Просмотр статистики:
За 24 часа: 1
За 7 дней: 4
За 30 дней: 10
За всё время: 4,914
