Инструменты для этого Разбора
Введение
Complete teardown of Sidekick II
Use the plastic opening tool to remove the 4 buttons on each corner of the Sidekick.
Gently pry open button and remove button.
Do this for each of the 3 buttons remaining.
The bumpers on the top and bottom of the phone can be removed by simply "peeling" them off.
Use the T6 Torx Screwdriver to remove the 4 screws that are underneath the 4 buttons you removed in step one.
Flip the screen up halfway (90 degrees), to reveal the 2 screws above the right side of the keyboard.
Use the Torx 6 screwdriver to remove these 2 screws.
After removing the 6 screws and both bumpers, the phone will be easy to separate into the two main bodies.
You can use your hands to simply pull apart the top casing from the bottom casing.
Remove 4 screws from back of screen using Torx 6 Screwdriver.
Pry screen out of casing using fingers.
Remove 4 screws from front of screen with Phillip screwdrivers.
Peel off the metal covering on the back of the screen.
Take the screws out using the Torx 6 screwdriver.
Then lift the thumb wheel and housing off of the front panel.
Remove the 5 black screws with a Phillips head screwdriver.
Lift the bottom of the control board from housing, and separate the two.
