Выберете то, что вам нужно
Это демонтаж а неруководство по ремонту. Чтобы отремонтировать Sony MDR-IF33K, воспользуйтесь нашим сервисным руководством.
  1. Sony MDR-IF33K Teardown, Sony MDR-IF33K Teardown: шаг 1, изображение 1 из 2 Sony MDR-IF33K Teardown, Sony MDR-IF33K Teardown: шаг 1, изображение 2 из 2
    • The main components of this kit are:
    • TMR-IF33 wireless transmitter
    • IFR-33 wireless receiver
    • 9V DC output AC adapter
    • Set of headphones
    • I'm not sure if this product was sold in North America, this one was purchased in Japan. In the second photo you can see the original packaging.
    • I do know that Sony used the same IR transmission system in some of its North American TVs - these components work with the wireless headphones that came with my old XBR TV.
  2. Sony MDR-IF33K Teardown: шаг 2, изображение 1 из 2 Sony MDR-IF33K Teardown: шаг 2, изображение 2 из 2
    • Here are top and bottom views of the TMR-IF33 infrared transmitter. The transmitter base holds a pivoting mast containing an IR LED array behind a dark filter/lens.
    • The transmitter has a stereo audio mini-jack input, stereo RCA jack inputs, and a 9V DC input jack. On the bottom there is a switch for normal/surround sound.
    • On the back you can see some keyed mounting holes for optional wall-mounting ofthe transmitter.
    • We'll take this transmitter apart first...
  3. Sony MDR-IF33K Teardown: шаг 3, изображение 1 из 1
    • First, remove the 3 screws in the recessed holes on the bottom of the transmitter using a Phillips #1 screwdriver.
  4. Sony MDR-IF33K Teardown: шаг 4, изображение 1 из 1
    • Once the screws are removed, you can lift off the bottom cover.
  5. Sony MDR-IF33K Teardown: шаг 5, изображение 1 из 2 Sony MDR-IF33K Teardown: шаг 5, изображение 2 из 2
    • Carefully disconnect the connector shown from the circuit board. The wires go to the infrared LED array, which we'll see in a moment.
    • The circuit board on this side is very plain. The green button on the left is the power switch.
    • Hopefully there's more to the transmitter circuit than that lone diode visible on this side...
  6. Sony MDR-IF33K Teardown: шаг 6, изображение 1 из 3 Sony MDR-IF33K Teardown: шаг 6, изображение 2 из 3 Sony MDR-IF33K Teardown: шаг 6, изображение 3 из 3
    • Here's the business side of the transmitter PCB, along with a couple closer views.
    • The transmitter consists of mainly discrete components. The lone IC in the 14 pin DIP packages is a BA3308F dual audio preamplifier.
  7. Sony MDR-IF33K Teardown: шаг 7, изображение 1 из 3 Sony MDR-IF33K Teardown: шаг 7, изображение 2 из 3 Sony MDR-IF33K Teardown: шаг 7, изображение 3 из 3
    • Next we'll open the housing for the IR transmitter array...
    • Using either your thumbnail or a spudger, carefully pry the housing open along the seam.
    • There are 3 hidden tabs on either side of the transmitter mast (see markers in 2nd photo). Pop these open carefully and the lens portion of the housing will come off.
  8. Sony MDR-IF33K Teardown: шаг 8, изображение 1 из 3 Sony MDR-IF33K Teardown: шаг 8, изображение 2 из 3 Sony MDR-IF33K Teardown: шаг 8, изображение 3 из 3
    • Here's the transmitter mast with the front lens/cover of the housing removed. Inside we see an array of infrared LEDs.
    • Next remove the 4 Phillips screws. Two of the screws fasten the metal hinge to the back half of the housing (one is partially obscured by the hinge in the first photo).
    • The other two screws fasten the LED circuit board to the back half of the housing.
    • The third photo shows a closer view of some of the infrared LEDs. There are 12 LEDs in all. They emit no visible light - but did you know? the IR beam can be seen by most camcorders and digital cameras.
    • The LEDs transmit the audio signal using FM modulation of the IR beam. The carrier frequencies used are 2.3MHz for the left channel, and 2.8MHz for the right. The specification for maximum range is 9 meters.
  9. Sony MDR-IF33K Teardown: шаг 9, изображение 1 из 3 Sony MDR-IF33K Teardown: шаг 9, изображение 2 из 3 Sony MDR-IF33K Teardown: шаг 9, изображение 3 из 3
    • Here's the disassembled transmitter housing and a view of the rear side of the LED array circuit board.
    • Ho hum... all discrete components here, nothing too exciting.
    • That's it for the transmitter. Next up, the receiver...
  10. Sony MDR-IF33K Teardown: шаг 10, изображение 1 из 2 Sony MDR-IF33K Teardown: шаг 10, изображение 2 из 2
    • Here are front and rear views of the IFR-33 infrared receiver. It's bigger than an iPod shuffle and carries no songs! ...or maybe it carries an infinite number of songs, connected to your stereo or other audio system, depending on how you look at it...
    • On the back, you'll find a swiveling clip and the battery compartment cover.
    • In use, the receiver can be clipped to your belt or shirt. The kit also comes with a lanyard (not shown) that let's you wear the receiver around your neck. Standard stereo earphones can be plugged into a jack at the bottom of the receiver.
    • The receiver is powered by a single AA battery.
  11. Sony MDR-IF33K Teardown: шаг 11, изображение 1 из 2 Sony MDR-IF33K Teardown: шаг 11, изображение 2 из 2
    • First, remove the screw in the center of the clip using a Phillips #0 screwdriver, and then remove the clip
  12. Sony MDR-IF33K Teardown: шаг 12, изображение 1 из 2 Sony MDR-IF33K Teardown: шаг 12, изображение 2 из 2
    • Next remove the battery cover.
    • This will reveal a screw which you can remove using a Phillips screwdriver
    • With this screw removed, you can now lift off the back half of the receiver case, revealing the circuitry inside.
  13. Sony MDR-IF33K Teardown: шаг 13, изображение 1 из 3 Sony MDR-IF33K Teardown: шаг 13, изображение 2 из 3 Sony MDR-IF33K Teardown: шаг 13, изображение 3 из 3
    • Carefully remove the bezel around the volume dial power switch and on/off indicator LED. Be careful not to lose the small power button cap which will come loose after removing the bezel
  14. Sony MDR-IF33K Teardown: шаг 14, изображение 1 из 2 Sony MDR-IF33K Teardown: шаг 14, изображение 2 из 2
    • The receiver circuitry resides on two small circuit boards soldered together perpendicularly.
    • To remove the circuit board, first carefully pull the battery contact/spring up out of its mounting slot. This should free the circuit board.
    • The 3 wires connect the circuit board to the stereo earphone jack (green).
  15. Sony MDR-IF33K Teardown: шаг 15, изображение 1 из 2 Sony MDR-IF33K Teardown: шаг 15, изображение 2 из 2
    • Here are a couple views of the receiver circuit board.
    • You can see the IR optical receiver under the large clear plastic lens. It's not obvious from the photos, but the cylindrical lens has a deeply concave front.
    • Once again, we notice mostly discrete components. The single IC in an 8 pin DIP package is a 2300B optocoupler chip.
  16. Sony MDR-IF33K Teardown: шаг 16, изображение 1 из 3 Sony MDR-IF33K Teardown: шаг 16, изображение 2 из 3 Sony MDR-IF33K Teardown: шаг 16, изображение 3 из 3
    • A few more other views of the receiver circuit.
  17. Sony MDR-IF33K Teardown: шаг 17, изображение 1 из 1
    • Finally, here are all the disassembled components.
    • That's it - I hope you found this interesting!
bac
Участник с: 10/13/09
9 829 Репутация
Автор 4 руководств
Один комментарий
Bonjour, mon récepteur ne fonctionne plus. Je ne comprends pas l'anglais et ne suis pas capable en électronique !
Où pourrais-je l'envoyer pour réparation.
Merci beaucoup
Léa ASTORG - Ответить
Добавить комментарий
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 2
За последние 30 дней: 9
За всё время: 14,777
