Введение
I have a PlayStation 1, and i have decided to make a new teardown of it.
I'm spanish, so my english is a bit poor, and sorry for the mistakes made in this teardown.
Without further delay, we start.
This teardown is not a repair guide. To repair your PlayStation, use our service manual.
  1. Here's the PS1. Turn the PS1 over and remove the six screws.
    • Here's the PS1.
    • Turn the PS1 over and remove the six screws.
    So far looking good. I'm commenting as you are making this teardown.
    Nicholas Ouimet - Ответить
  2. Remove the top cover. It's very easy.
    • Remove the top cover. It's very easy.
  3. Disconnect both CD-ROM connectors.
    • Disconnect both CD-ROM connectors.
    • CD connector one and the socket it connects to.
    • CD connector two and the socket it connects to.
  4. Remove the CD-ROM reader. You should be able to pull it out gently, although you may have to wiggle it around a bit to loosen the rubber holders. Remove the CD-ROM reader. You should be able to pull it out gently, although you may have to wiggle it around a bit to loosen the rubber holders.
    • Remove the CD-ROM reader. You should be able to pull it out gently, although you may have to wiggle it around a bit to loosen the rubber holders.
  5. Detach both cables. They go to the power supply and to the memory cards and controller connectors.
    • Detach both cables. They go to the power supply and to the memory cards and controller connectors.
  6. Remove the four screws and the metal cover.
    • Remove the four screws and the metal cover.
  7. Now you have the motherboard!
    • Now you have the motherboard!
    • And the power supply.
    • Remove the four screws from the motherboard and the power supply.
  8. Once the screws are removed, remove the power supply.
    • Once the screws are removed, remove the power supply.
  9. Remove the motherboard, and both of the screws from the memory card/ controller connection mechanism.
    • Remove the motherboard, and both of the screws from the memory card/ controller connection mechanism.
  10. Now, you have all your PlayStation 1 parts!
    • Now, you have all your PlayStation 1 parts!
    • Main Board
    • Lower Casing
    • EMI Shield
    • Power Supply
    • Disk Reader
    • Memory Card/ Controller Mechanism
imacg517
Участник с: 06.05.2010
164 Репутация
1 Guide authored
Один комментарий
That’s a PAL PS1. May be different from NTSC models.
Daniel Powers - Ответить
Добавить комментарий
Просмотр статистики:
За 24 часа: 6
За 7 дней: 44
За 30 дней: 146
За всё время: 20,324
