Введение
The aim is simple, to teardown the Xperia U to allow you to see the internals to find out the issue and resolve it or to full your curiosity. And only containing 9 screws.
You will need a T5 Screw head and a small + screw
Выберете то, что вам нужно
Remove the back cover and the bottom clip. And also remove the sim card and battery.
Remove the back piece, reveiling the headphone jack, speaker and the Liquid contact indicator.
Camera and flash
Vibrating motor
Headphone jack
Speaker
Carefully remove the motherboard being aware on the lower left edge, there is the display connector.
Removal back and bottom cap
Screen + main case, motherboard + antenna, battery
Back casing holding the headphone jack, speaker and liquid contact indicator.
