ΠΡΠ±Π΅ΡΠ΅ΡΠ΅ ΡΠΎ, ΡΡΠΎ Π²Π°ΠΌ Π½ΡΠΆΠ½ΠΎ
ΠΠΈΠ΄Π΅ΠΎ ΠΎΠ±Π·ΠΎΡ
Release all the connectors on board and remove the screws there.
Cut the adhesive on the top of the audio jack and remove the audio jack assembly.
Release connectors connecting on the antenna logic board and finally remove it.
Release LCD connector there and loosen the bottom of the whole flex.
Remove LCD screen carefully.
Gerade so ein schwieriger Schritt, wie das Entfernen des Displays, bei dem auch echt viel schief gehen kann, sollte ruhig etwas detaillierter beschrieben werden. Die MΓΌhe ist man der Community echt schuldig.
Davon mal abgesehen ist das Bildmaterial echt gut gelungen!
2 ΠΠΎΠΌΠΌΠ΅Π½ΡΠ°ΡΠΈΠ΅Π²
Is it possible to replace the nylon corners? I've heard it was possible in the previous xperia z devices like z2 and z3. Unfortunately I couldn't find the replacement corners for z3+ or z4 anywhere. Anyone has any idea about it?
Late answer, but it seems like thereβs replacement parts for the corners now. I donβt know how to replace them, though.
How much heat needed to melting down the back cover adhesiveβ¦
Aspar Riansyah - ΠΡΠ²Π΅ΡΠΈΡΡ
it is no need to heat too much.
Snowflake -
