Введение
This TL-WR802N router is designed for mobile use, with speeds up to 300 Mbps. It uses a micro USB port for power only, and only has 1 ethernet port.
Выберете то, что вам нужно
Inside the device contains:
Speeds up to 300 Mbps; 2x2 MIMO antenna setup; 5 modes which can turn it into a WiFi extender, or a Wi-Fi client to connect wired only devices to Wi-Fi.
On the outside:
Green LED indicator
10/100 Ethernet port; can be used as a WAN or LAN
Micro USB for power
Recessed Reset Button
On the top of the router, there is a blue panel that is the case. It is held on by clips, holding it in place.
The top panel can be removed by using a small flat bladed screwdriver and inserting it into the gap between the case and the panel itself.
Once the cover is loose, the cover can be removed, revealing the router's main circut board.
With the top panel removed, we can now see the internal components.
A spudger was used to lift the circuit board out of the case.
On the front of the board:
Qualcomm Atheros QCA9533-AL3A SoC
Running at a speed of 560 MHz
Uses the MIPS 24Kc architecture
Contains an integrated Ethernet switch and wireless radio built in.
2 soldered antennas that allows a MIMO configuration of 2x2:2.
Most of the information that I can obtain are from Wikidevi at: https://wikidevi.com/wiki/Qualcomm_Ather...
Back of the board:
Zentel A3S56D40GTP-50L RAM chip with 32 MB
Windond 25Q32FVS1 SOIC Flash chip with 8 MB
And that's It!
The router in this teardown is v1.0. There is another version of the same router, called V2.0, which is virtually identical, however it will only accept firmware that was sold in that country.
For a very small device it can do alot! But it can do more if the OpenWrt/LEDE firmware was ported over.
8 Комментариев
Is it possible to remove the 2 antennas and ad external antennas instead… and how Should it be done…
Best regards
Hi
Is it possible to remove the 2 antennas and replace them with external antennas instead… and how should this be done…
Best regards
i’m sure you can just how you do it i’m not sure
Luke -
This TP Link Router is awesome. I like it. i think we can add external antennas in it.
flash openwrt
