Введение
This is the Teardown of all Important Componets (Maybe not all,but SSD,RAM,Heatsink,Fans,USB Port with the Right Speaker and the Battery) of Acer Aspire A515-47.
To assemble your Acer Aspire A515-47 Laptop,just follow all the steps,but backwards.But be more careful when you assemble the pieces
Выберете то, что вам нужно
Alright,so,first things first,unscrew all the Screws from the Case
Then,use a prying tool to open the Case
Alright,after you pried open the case,put it somewhere where it wont bother you
Good,you took out the case.Now,go to the SSD
Do you see that screw that holds down the SSD? Yea,unscrew that screw and put it somewhere where you wont lose it.You are gonna need it at assembly
Now,just pull gently on the SSD and you are done
Alright,so,the RAM is hold by the two metal pieces that are marked by me.You just have to pull outwards the metal
Then,you just take the RAM out Slowly
First,Unscrew all three screws that hold the Heatsink.
After you took out the screws,lift the heatsink up a bit and just take it out.Its very easy
First,unscrew the Screws of the fans
Then,just pull the fans gently and you are done
Well,here is very simple.All you have to do is to unscrew the screw and put it somewhere where you wont lose it
Then,just pull it out gently
First,remove the Screw that holds the USB Port and lift up the Ribbon Connector and take out the ribbon gently
Now,just lift the port part.Its very easy to do that.The speaker is connected to the USB Port
First,Remove the Screws and lift up the Ribbon Connnectors.Then,lift the black tape a bit
Then,take out the Ribbons
Now,you can lift up the battery,but not completly
