Запчасти
Введение
The Timex TX5020 is an electronic thermometer that can be used both indoors and outdoors. It requires only a screwdriver to take apart.
Это демонтаж а неруководство по ремонту. Чтобы отремонтировать Timex TX5020 LCD Electronic Thermometer, воспользуйтесь нашим сервисным руководством.
  1. Here is the fully assembled thermometer. Here is the fully assembled thermometer.
    • Here is the fully assembled thermometer.
  2. Slide the battery compartment cover off by applying downward and forward pressure.
    • Slide the battery compartment cover off by applying downward and forward pressure.
  3. Loosen and remove the four screws from the back of the thermometer. Loosen and remove the four screws from the back of the thermometer.
    • Loosen and remove the four screws from the back of the thermometer.
  4. Lift the back panel away from the rest of the case.
    • Lift the back panel away from the rest of the case.
  5. Remove the three screws holding the circuit board in place. Remove the three screws holding the circuit board in place.
    • Remove the three screws holding the circuit board in place.
  6. Lift the circuit board away from the case. Be careful not to pull too hard as the board is attached to the battery contacts.
    • Lift the circuit board away from the case.
    • Be careful not to pull too hard as the board is attached to the battery contacts.
  7. Remove the screen from it's compartment. Remove the push buttons from their compartment.
    • Remove the screen from it's compartment.
    • Remove the push buttons from their compartment.
  8. Here's a full view of the disassembled components (circuit board, screen, push buttons, and case).
    • Here's a full view of the disassembled components (circuit board, screen, push buttons, and case).
Chris L
Участник с: 17.12.2014
1 354 Репутация
Автор 3 руководств
Комментариев: 0
Добавить комментарий
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 3
За последние 30 дней: 10
За всё время: 1,419
