Выберете то, что вам нужно
Loosen this screw, and pop out the RAM cover.
Undo the module clamps, gently lift the end of the module to a 45-degree angle and pull it out. Do the same for the one below.
Loosen these 3 screws, and pop out the two hard drive bay covers
Pull out the plastic tab located here, and pull it gently but firmly to the right.
Remove this screw, it might require tweezers after loosening to get out.
Insert a paper clip into this hole, which will pop out the drive
Grasp the drive tray and gently but firmly pull it out of the laptop chassis.
Remove these screws
Flip the laptop over, and push the bezel towards the lcd while lifting up, this might require some force.
Remove the two screws at the top of the keyboard
Guide the keyboard towards the LCD, and lift up slightly, be careful of the ribbon cable underneath
Using a spudger or fingernail, carefully push one side, then the other of the keyboard ribbon connector toward the LCD, releasing it.
Remove the 2 screws on the bottom of the laptop
Disconnect the LCD cable and thread it out of its path so it's free
Using a spudger or fingernail pop off the two wifi antennas and thread them out too
Remove this screw from the top of the laptop
Remove these 12 screws from the bottom of the laptop
Carefully, using a spudger or fingernail, release the touchpad ribbon cable from its connector.
Run your fingernail or spudger along the crack between the top bezel and bottom casing at the back of the laptop, and proceed to release the clips and lift off the bezel.
Remove this screw
Okay, don't freak out, but there are a BUNCH of clips and connectors to undo at this point, just keep calm and know where your towel is and all will be well.
Disconnect, using a spudger or fingernail, the following connectors:
USB header
Speakers
Power/media buttons
VGA connector and screw
Fan power
Modem connector (lift up tape)
Peel back the metallic tape from the fan
Lift the fan up and away from the vent
Tough part: Lift the motherboard at the rop right corner, find this cable underneath and gently wiggle it out.
Lift the board out, pivot it slightly to allow the audio connectors to come free, then simply lift.
Remove these four screws, and slide the bracket off
Carefully lift up the heatsink
Using a flathead, turn this to release the processor
Phew! Here we go, guts and all. Give yourself a pat on the back, and follow these instructions in reverse to reassemble.
5 Комментариев
are you selling these parts? i desperately need a new screen for mine. Or do you know where I can find the screen replacement part??
you can email me at bleadinluv@gmail.com thank you bunches
erica
Is there a separate sound module? My A215 works great except for the sound which is nothing but crackle/static even with sound turned to very low. Same thing using headphones so the speakers themselves seem to be ok.
