This teardown is not a repair guide. To repair your Toshiba Satellite M45, use our service manual.
  1. If the device is still running, please turn the computer off properly and then disconnect the power supply from the power supply port in the back of the computer. Remove battery before beginning any work to reduce electrical shock and to prevent damage to the electrical components. Locate and slide the 2-battery locks to disconnect the battery.
    • If the device is still running, please turn the computer off properly and then disconnect the power supply from the power supply port in the back of the computer.
    • Remove battery before beginning any work to reduce electrical shock and to prevent damage to the electrical components.
    • Locate and slide the 2-battery locks to disconnect the battery.
    • Remove the battery by sliding it out away from the computer (horizontal with the casing).
  2. Remove the ODD screw with a #1 Phillips head screwdriver as indicated in the picture. Using a flat edge tool, pry it the drive out of it slot from the side of the casing. You can then use your hands to continue pulling the rest the way out of its slot. Using a flat edge tool, pry it the drive out of it slot from the side of the casing. You can then use your hands to continue pulling the rest the way out of its slot.
    • Remove the ODD screw with a #1 Phillips head screwdriver as indicated in the picture.
    • Using a flat edge tool, pry it the drive out of it slot from the side of the casing. You can then use your hands to continue pulling the rest the way out of its slot.
  3. Use a #1 Phillips head screwdriver to remove the screws on the RAM's cover panel, as seen in image. Then, use a flat edge tool to pry the cover off, as seen in image. Use your fingers to push the RAM tabs, as seen in image, that secure the RAM outward (away from the RAM). The RAM should then pop up.
    • Use a #1 Phillips head screwdriver to remove the screws on the RAM's cover panel, as seen in image.
    • Then, use a flat edge tool to pry the cover off, as seen in image.
    • Use your fingers to push the RAM tabs, as seen in image, that secure the RAM outward (away from the RAM). The RAM should then pop up.
    • Finally, gently pull the RAM away from the connection. (Repeat this process until all the RAM has been removed from the device).
  4. Remove the hard drive screw labeled with a #1 Phillips head screwdriver  as indicated in the picture, then use a flat edge tool to pry the cover off. Use the plastic flap to pull the hard drive out of its slot. Use the plastic flap to pull the hard drive out of its slot.
    • Remove the hard drive screw labeled with a #1 Phillips head screwdriver as indicated in the picture, then use a flat edge tool to pry the cover off.
    • Use the plastic flap to pull the hard drive out of its slot.
  5. Remove the panel screw labeled with a #1 Phillips head screwdriver  as indicated in the picture, then use a flat edge tool to pry the cover off. The hardware to the left (labeled) can be easily removed by disconnecting the black and white wires and pushing the tabs that secure it (located on the side) outwards. Pull the Wi-Fi card out from the device at a slight angle (horizontal with the casing).
    • Remove the panel screw labeled with a #1 Phillips head screwdriver as indicated in the picture, then use a flat edge tool to pry the cover off.
    • The hardware to the left (labeled) can be easily removed by disconnecting the black and white wires and pushing the tabs that secure it (located on the side) outwards.
    • Pull the Wi-Fi card out from the device at a slight angle (horizontal with the casing).
  6. Using a bladed tool, gently pry up the display hinge cover. Using a bladed tool, gently pry up the display hinge cover.
    • Using a bladed tool, gently pry up the display hinge cover.
  7. After folding the display completely back, lift up on the display hinge cover and remove it. After folding the display completely back, lift up on the display hinge cover and remove it.
    • After folding the display completely back, lift up on the display hinge cover and remove it.
  8. Remove the keyboard. For keyboard removal instructions, see the keyboard guide here: Toshiba Satellite M45 Keyboard Replacement
  9. iPhone Battery Fix Kits
    Only $29.99
    Buy Now
    Only $29.99
    Buy Now
  10. Remove the black electrical tape covering the black-and-white antenna cable. There will be 2-3 pieces of tape.
    • Remove the black electrical tape covering the black-and-white antenna cable. There will be 2-3 pieces of tape.
    • After the tape has been removed, close the laptop display, flip the laptop over, and disconnect the black-and-white antenna cables from the WiFi Card.
    • For information about accessing the WiFi Card, see the WiFi Guide here: Toshiba Satellite M45 Wi-Fi Card Replacement
    • Once the antenna cables are disconnected from the modem card, flip the laptop back over and open the display.
  11. Remove the two screws securing the display hinges with a #1 size Phillips head screwdriver. It is recommended to keep the screws in a small cup so that you don't lose them. Remove the four screws on the back of the laptop holding the screen in place with a #1 screwdriver. There are two on each side. Remove the four screws on the back of the laptop holding the screen in place with a #1 screwdriver. There are two on each side.
    • Remove the two screws securing the display hinges with a #1 size Phillips head screwdriver. It is recommended to keep the screws in a small cup so that you don't lose them.
    • Remove the four screws on the back of the laptop holding the screen in place with a #1 screwdriver. There are two on each side.
  12. Remove the display's video connector by gently pulling up.
    • Remove the display's video connector by gently pulling up.
    • Remove the black-and-white antenna cable from the groove.
    • Your display can now be removed.
  13. Carefully pry the panel above the keyboard from both sides of the laptop using the iFixit opening tool. Push back the screen until it is horizontal with the laptop. Gently remove the clips that connect the panel to the screen.
    • Carefully pry the panel above the keyboard from both sides of the laptop using the iFixit opening tool.
    • Push back the screen until it is horizontal with the laptop.
    • Gently remove the clips that connect the panel to the screen.
  14. Remove the two screws using a Phillips #1 screwdriver. Gently pry the keyboard from the laptop using the iFixit opening tool. Slowly lift the keyboard away from the laptop until you are able to remove the ribbon that connects to the laptop.
    • Remove the two screws using a Phillips #1 screwdriver.
    • Gently pry the keyboard from the laptop using the iFixit opening tool.
    • Slowly lift the keyboard away from the laptop until you are able to remove the ribbon that connects to the laptop.
    • Ensure you remove the keyboard slowly to avoid damaging the ribbon cable.
  15. Located near the upper edges of the motherboard you will find the 2-speaker wires that trace to the speakers. You will see these white tab with black and red wires. Unscrew the 2-screws located above the speakers to remove them. Slowly pull up on the speakers as there are other port connectors are located near the wiring. Unscrew the 2-screws located above the speakers to remove them. Slowly pull up on the speakers as there are other port connectors are located near the wiring.
    • Located near the upper edges of the motherboard you will find the 2-speaker wires that trace to the speakers. You will see these white tab with black and red wires.
    • Unscrew the 2-screws located above the speakers to remove them. Slowly pull up on the speakers as there are other port connectors are located near the wiring.
  16. To remove the left speaker follow the motherboard repair guide to complete this step to keep this guide concise. Reverse the order after installing the new speakers.
    • To remove the left speaker follow the motherboard repair guide to complete this step to keep this guide concise.
    • Reverse the order after installing the new speakers.
  17. Remove the cover from the cooling unit. Remove the cover from the cooling unit. Remove the cover from the cooling unit.
    • Remove the cover from the cooling unit.
  18. Unscrew the copper heat-sink using a #1 screwdriver, and then lift it free. Do not get any thermal grease on any components. This part can now be replaced. Unscrew the copper heat-sink using a #1 screwdriver, and then lift it free. Do not get any thermal grease on any components. This part can now be replaced.
    • Unscrew the copper heat-sink using a #1 screwdriver, and then lift it free. Do not get any thermal grease on any components. This part can now be replaced.
  19. Follow the tear-down guide until you have access to the fan unit on the motherboard.
    • Follow the tear-down guide until you have access to the fan unit on the motherboard.
  20. Unscrew the fan unit from the motherboard using a #0 screwdriver. Once the fan is unscrewed and unplugged from the motherboard, it can be replaced. Unscrew the fan unit from the motherboard using a #0 screwdriver. Once the fan is unscrewed and unplugged from the motherboard, it can be replaced. Unscrew the fan unit from the motherboard using a #0 screwdriver. Once the fan is unscrewed and unplugged from the motherboard, it can be replaced.
    • Unscrew the fan unit from the motherboard using a #0 screwdriver. Once the fan is unscrewed and unplugged from the motherboard, it can be replaced.
  21. Disconnect the video cable near the left speaker slowly but firmly pulling upwards. Disconnect the brown ribbon that is located directly in the middle of where the keyboard one was away from the connector. Disconnect the 2-other white ribbons located near the top right half of the keyboard section pulling firmly away from the connector.
    • Disconnect the video cable near the left speaker slowly but firmly pulling upwards.
    • Disconnect the brown ribbon that is located directly in the middle of where the keyboard one was away from the connector.
    • Disconnect the 2-other white ribbons located near the top right half of the keyboard section pulling firmly away from the connector.
  22. Unscrew all the screws labeled using a micro-screwdriver turning counterclockwise. There are 3-additional screws that need to be removed through the 3-holes located in the optical drive.
    • Unscrew all the screws labeled using a micro-screwdriver turning counterclockwise.
    • There are 3-additional screws that need to be removed through the 3-holes located in the optical drive.
  23. Using a flat-edge tool begin to pry away the case apart and slowly pulling upward as there is a white ribbon that need to be removed. Make sure to completely untape the largest white ribbon, and let it slide through the top half of the case as you lift it. Make sure to completely untape the largest white ribbon, and let it slide through the top half of the case as you lift it.
    • Using a flat-edge tool begin to pry away the case apart and slowly pulling upward as there is a white ribbon that need to be removed.
    • Make sure to completely untape the largest white ribbon, and let it slide through the top half of the case as you lift it.
  24. Now lift out the motherboard. Be careful not to rip any of the pieces out, just wiggle them out. Now lift out the motherboard. Be careful not to rip any of the pieces out, just wiggle them out.
    • Now lift out the motherboard. Be careful not to rip any of the pieces out, just wiggle them out.
  25. Congratulations, your computer has been completely dismantled!
    • Congratulations, your computer has been completely dismantled!
    • Now, reverse the steps to reassemble.
Bobby Davis
Участник с: 11.03.2014
154 Репутация
1 Guide authored
Команда
UMass Dartmouth, Team 4-1, Calaway Spring 2014 Member of UMass Dartmouth, Team 4-1, Calaway Spring 2014
UMASSD-CALAWAY-S14S4G1
3 членов
1 Guide authored
Комментариев: 0
Добавить комментарий
Просмотр статистики:
За 24 часа: 1
За 7 дней: 2
За 30 дней: 3
За всё время: 1,880
