Введение
The following tear down provides a step by step guide to completely disassemble a Palm Tungsten E.
This teardown is not a repair guide. To repair your Tungsten E, use our service manual.
  1. Remove stylus and SD card.
    • Remove stylus and SD card.
    • Using T-5 torx driver, remove 4 back panel screws.
    • The screws are small and can be lost easily. Be sure to place them in a secure area.
  2. Begin to remove back cover by inserting the plastic opening tool under the usb and power input slots.
    • Begin to remove back cover by inserting the plastic opening tool under the usb and power input slots.
    • Continue by sliding the plastic opener to the right at the markers shown until the cover releases.
    • Your device may not have a screen protector. If not, you do not need to complete step three. Please move on to step four.
    • Remove screen protector by lifting hinge out of plastic housing.
    • Remove top cover by gently pulling away from the device with plastic tool
    • Carefully remove motherboard from the standoffs without damaging the LCD flex connector.
    • Using spudger( the black pencil-like tool shown in picture two), unlock both sides of the flex connector block (shown in the purple boxes in picture two) by pushing down.
    • Remove motherboard completely.
    • Metal washers may pop out of the device during this step
    • Remove buttons using fingers.
    • Gently flex frame to release screen from plastic frame.
    • Lift out screen.
    • Congratulations! You have successfully taken apart a Palm Tungsten E.
Kevin Hom
Участник с: 21.01.2010
88 Репутация
Автор 2 руководств
Команда
Cal Poly, Team 13-22, Maness Winter 2010 Member of Cal Poly, Team 13-22, Maness Winter 2010
CPSU-MANESS-W10S13G22
4 членов
Автор 4 руководств
Один комментарий
How does one unplug the battery?
dlcatftwin - Ответить
Просмотр статистики:
За 24 часа: 0
За 7 дней: 0
За 30 дней: 7
За всё время: 6,637
