Введение
Having trouble dismantling the Vornado Flippi V6 fan?
This guide shows show you how to disassemble the fan step by step.
Выберете то, что вам нужно
Under the base of the fan, remove the four rubber slip guards by peeling them off with your finger tips.
Using the Phillips #1 screwdriver, remove the four 2mm screws underneath the slip guards.
After removing the base of the fan, remove the two screws located under the adjustable speed switch.
Using two hands, pull the sides out carefully. You will hear a "pop" noise, indicating the sides have came out.
To remove the adjustable speed switch cover, slightly pry off 6 clips located around the switch.
10 Комментариев
Importantly several of the parts have a specific difference between left and right. The cradle and the fan housing itself have a small and a large “bearing” for setting fan angle. The logo goes down. If they don’t match the cradle you cannot reassemble the fan. I took mine apart because the fan bearings needed oil.
What kind of oil and where exactly do you apply it? I have a couple of these that are getting noisey
Aaron -
I would also like to know what kind of oil and where exactly to apply it? One of mine is squeaking loud enough that I haven't been using it. Taking it apart for a thorough cleaning did not do the trick.
Thanks!
