Введение
Western digital Hard drive tear down
Remove 6 perimeter screws
Remove screw from under sticker
Lift cover off
Inside of hard drive
Desiccant packet removed from lower right corner
Inside of cover
Stops to limit head travel
Red coil over magnet cause the head to rotate
Contact block installed
Remove two screws, contact block is now loose but connected to head by a ribbon cable
Disk installed
Remove 3 screws holding down collar
Remove collar
Head installed, simply lift head out of case
Remove head
Case without head
Removed head
Contacts for data and head control
Head interface to disk
