Выберете то, что вам нужно
Видео обзор
Это демонтаж а неруководство по ремонту. Чтобы отремонтировать Xbox One X, воспользуйтесь нашим сервисным руководством.
    Заключительные мысли
    • Only a few tools are required to take the whole console apart.
    • Once inside, a clean, no-nonsense modular design allows the drives, fan, heat sink, PSU, wireless board, and front daughterboard to be easily replaced.
    • Fewer interlocking body panels and a simpler clip arrangement make opening this generation of Xbox easier than its senior.
    • Replacing the hard drive will require both voiding your warranty and some difficult hackery to make it serviceable.
    Уровень ремонтопригодности
    8
    Ремонтопригодность 8из 10
    (10 легче всего ремонтировать)
21 Комментариев
Uhg, the HDD reformat is the worst part. Why are we getting so many devices without guides? The video is more for entertainment than help for repair. I'd rather have less teardowns with complete guides. Last of all, why don't we get a Pixel 2 teardown? That's like getting a iPhone 8 plus teardown but no regular teardown. Especially considering the regular model is probably more popular.
George A. - Ответить
Hi @pccheese! We’ll have guides eventually, but they take much longer to create than a teardown. You’re right, teardowns are not meant to be used as instructions and are no substitute for a proper guide. As far as Pixel 2, our team is small and we only had the bandwidth for a full teardown on one of the two Pixel phones. The XL was chosen in part because it has gotten more attention, due to the more dramatically updated design. FYI the vanilla Pixel 2’s internals look very, very similar to the original Pixel XL, but with the addition of the same Active Edge strain gauges we saw in the 2 XL.
Jeff Suovanen -
@jeffsu If you have these devices and you are tearing them down internally, perhaps iFixit can take the pictures and the community could write the guides. I have no problem writing the guides- but my photography setup isn't always set up when I'm about to fix something.
A proper step by step teardown is much more helpful for repair then a video. I'm sure people use the teardown all the time for repair on many devices.
George A. -
@jeffsu So what about the guides?
George A. -
Taking pictures is actually quite time-consuming, otherwise I’m sure we’d take you up on that. :) Bear with us a bit, the guidewriting team is down a few people so our pace is definitely not what we’d like it to be in terms of guide production at the moment. We’re working on it!
Jeff Suovanen -
Добавить комментарий
Просмотр статистики:
За последние 24часов: 28
За последние 7 дней: 205
За последние 30 дней: 899
За всё время: 169,863
