Выберете то, что вам нужно
Это демонтаж а неруководство по ремонту. Чтобы отремонтировать Xbox, воспользуйтесь нашим сервисным руководством.
  1. Xbox Teardown, Taking of the Top: шаг 1, изображение 1 из 1
    • Flip over the Xbox to where it shows the bar codes. Take of the black grips. Also scratch around where it has the stickers to find the screws there are a total of six, 2 of the screws are within the stickers.
  2. Xbox Teardown, The Top: шаг 2, изображение 1 из 1
    • (This photo is not mine it was from another ifixit and i will use 5 photos from them since i couldn't find the ones i took)
    • When you get the screws off use the spudger to get it open by finding a crack that goes all around the xbox
  3. Xbox Teardown, Removing the Hard Drive pt1: шаг 3, изображение 1 из 1
    • After you take of the top you will see all the circuits.
    • Look around and you will find 3 screws that are holding down the disc drive and remove them.
  4. Xbox Teardown, Removing the Hard Drive pt2: шаг 4, изображение 1 из 1
    • When you do that just take off the disc drive depending on what you are trying to fix just unplug the wires going to it and set it aside.
  5. Xbox Teardown, Removing the Disc Drive: шаг 5, изображение 1 из 1
    • Unplug any wires that seem to be poking out then take out the disc drive which should just come out.
    • Same thing if its not your focus just put it to the side.
  6. Xbox Teardown, The Ribbon: шаг 6, изображение 1 из 1
    • The rest are my pictures
    • Remove the ribbon carefully
  7. Xbox Teardown, The Rainbow Wire: шаг 7, изображение 1 из 1
    • Somewhere on the motherboard there will be a multi-colored wires that are together and just simply unplug it.
  8. Xbox Teardown, Removing the Transformers: шаг 8, изображение 1 из 1
    • To the left of the Rainbow wire there are a lot of transformers which we will need to take out.
    • There will be screws holding it down so just look around the transformers.
    • Disconnect any wires that are connected to it before picking it up.
    • Set it aside if its not what you are going for.
  9. Xbox Teardown, The Motherboard: шаг 9, изображение 1 из 1
    • When the transformers are gone look around the motherboard which should be the last electronic left.
    • There also will be screws around,when you find them unscrew them and all you have to do know is carefully take out the motherboard
    • Then your done at taking out the motherboard.
Justin Moreno
Участник с: 11/08/16
219 Репутация
1 руководство автора
Один комментарий
you forgot to mention the fan shroud, which, if i remember correctly is a bit tricky to remove
pantsaremyfriend - Ответить
Добавить комментарий
Просмотр статистики:
За последние 24часов: 2
За последние 7 дней: 15
За последние 30 дней: 55
За всё время: 6,461
