Введение
Xiaomi Mi Mix 2 is easy to repair. If you got your Mi Mix 2 broken by accident, you can repair it by yourself. This video show you how to disassemble Mi Mix 2 step by step.
За последние 24часов: 0
За последние 7 дней: 3
За последние 30 дней: 29
За всё время: 11,154
3 Комментариев
I wish this guide was step by step.
BootlegScarce - Ответить
can I replace the battery without first removing the motherboard?
Danny Di clemente - Ответить
I would like to recommend not to disconnect the signal cables unless it is absolutely necessary . The screen can be replaced whithout disconnecting them. I learned it the hard way ,once two connector broke ,one on the mainboard and another on the cable, I had to remove them and solder the cable directly to the mainboard
Albert Teix - Ответить
