Помощь
Редактирование шага 12 —
Тип шага:
Перетащите чтобы изменить порядок
Sometimes EMI shields can be scary/tricky to remove, depending on which procedure a manufacturer uses to attach them to the motherboard. In some cases, the shields are soldered directly to the motherboard (the worst scenario), while in others the frames of the shields are soldered, but the top covers are removable.
…Unless EMI shields happen to be screwed in, as is the case here. We love screws, especially when they hold in components that typically require desoldering.
This is the first device we've seen with screwable EMI shields. Props to you, Samsung.
Ваш вклад лицензируется под свободной лицензией Creative Commons.
