Отремонтируйте ваше устройство
Обучение ремонту
Магазин
Помощь
Редактирование шага 7 —
Тип шага:
Перетащите чтобы изменить порядок
The inside of your tablet will more than likely look less battle scarred than mine at this point. I decided to take my photos during the re-assembly stage - thus all the scars.
To remove the front facing camera (right,) use your spudger to unlock the ribbon cable and slide the camera out.
To remove the rear facing camera (left,) unplug it from it's socket by applying light lifting pressure to the back of the cable.
Remove the backup battery on the right side by unplugging the cable from the motherboard with your spudger and then prying it out. It is glued down lightly with adhesive.
Ваш вклад лицензируется под свободной лицензией Creative Commons.
