Помощь
Редактирование шага 12 —
Тип шага:
Перетащите чтобы изменить порядок
Push up on the trigger pin to remove it. These are ment to be loose fitting for easy teardown.
Once pin is out, the hammer will just slide out.
The next step is only on series 80 styles. Underneath the hammer is the safety lever that pushes up on the firing pin block in the slide when the trigger is pulled.
Remove safety lever, it will just fall out (tweezers are just for show).
Ваш вклад лицензируется под свободной лицензией Creative Commons.
