Помощь
Редактирование шага 7 —
Тип шага:
Перетащите чтобы изменить порядок
Survey says: a six-degrees-of-freedom magnetic sensor coil for tracking the position of the controller.
The intensity of the three perpendicular magnetic fields is measured to determine the position and orientation of the controller relative to the headset.
Cracking open the controller, we find the (much bigger) emitting half of the tracker, and an 8.4 Wh battery to boot.
The copper shielding sprayed into the coil housings likely protects from RF interference, while letting the magnetic field through.
Interference could explain the tracker's odd placement, and this may be a temporary solution. It's "old" tech, and will probably be worse for left-handed use.
Not pictured: we also dug up what looks like a custom-designed trackpad ringed with LEDs (for future light-tracking hardware, perhaps?).
Ваш вклад лицензируется под свободной лицензией Creative Commons.
