Помощь
Редактирование шага 9 —
Тип шага:
Перетащите чтобы изменить порядок
... gently flip up the black catch at the edge of the ribbon cable connector. You can now pull the ribbbon cable out of the connector.
In the 2nd photo, you can see the bottom plate, along with rear button switches, and battery door microswitch.
Note: there is still a clear plastic insulating sheet attached between this assembly and the camera. It will be detached at a later step.
Ваш вклад лицензируется под свободной лицензией Creative Commons.
