Fix Your Stuff
Right to Repair
Parts & Tools
Помощь
Редактирование шага 20 —
Тип шага:
Перетащите чтобы изменить порядок
Lesson learned about adhesive in this teardown—we go straight to the iOpener in order to get the battery out of its sticky cage.
As always, we are ignoring some kind of warning. This time, it tells us not to remove the battery from the back cover. Apparently, to safely replace your battery you will need a whole back cover assembly.
We don't understand the point of heavily-glued batteries. This kind of planned obsolescence is completely unnecessary.
We assume the sweet camo pattern on the rear case interior is an insulating coating applied to the otherwise conductive panel.
Ваш вклад лицензируется под свободной лицензией Creative Commons.
