Отремонтируйте ваше устройство
Обучение ремонту
Магазин
Помощь
Редактирование шага 13 —
Тип шага:
Перетащите чтобы изменить порядок
The Motorola Razr earns a 1 out of 10 on our repairability scale (10 is easiest to repair):
The only driver you'll need is a standard T3 Torx.
The delicate primary display is replaceable, if you're determined.
Every repair starts (and ends) with stubborn, glued-on outer covers.
Replacing the battery—or rather, batteries—requires near-total disassembly.
The charging port is soldered directly to the main board.
Complex construction and multiple flex cable booby traps makes for tricky repair work.
Ваш вклад лицензируется под свободной лицензией Creative Commons.
