Помощь
Редактирование шага 4 —
Тип шага:
Перетащите чтобы изменить порядок
Removing the rear case simply requires prying a few clips around the perimeter of the Z10. Easy peasy.
The rear panel contains an integrated NFC antenna, similar to the antenna found in the Samsung Nexus S.
To avoid running a cable between the body and rear panel, the NFC antenna has two contact points that line up with spring contacts on the motherboard.
Ваш вклад лицензируется под свободной лицензией Creative Commons.
