Fix Your Stuff
Right to Repair
Parts & Tools
Помощь
Редактирование шага 7 —
Тип шага:
Перетащите чтобы изменить порядок
Once you have removed the trim you will see 4 gold screws at the corners of the phone. Using a T5 Torx Screwdriver, remove the screws.
Gently, use The Spudger towards the edge of the phone, lift the face plate off.
Be careful during this step, the touch-sensitive keys and logic board (which is green) may remain attached to the face plate. Gently hold the chip board down as you lift the face plate.
Ваш вклад лицензируется под свободной лицензией Creative Commons.
