Отремонтируйте ваше устройство
Обучение ремонту
Магазин
Помощь
Редактирование шага 17 —
Тип шага:
Перетащите чтобы изменить порядок
Macintosh 128K Repairability Score 7 out of 10 (10 is easiest to repair).
Once you’re inside, it’s simple and straightforward to replace any of the main components: floppy drive, power supply, logic board, or CRT display.
No adhesive anywhere.
User-replaceable clock battery.
Limited upgradability: The RAM is soldered to the logic board and can’t be replaced, and there’s no slot/port to add an internal drive. However, you can expand storage via an optional external floppy drive.
The case is fairly difficult to open, with deeply recessed screws and a tight panel fit.
There are some dangerous high voltages on both the power supply and the CRT that make repair potentially hazardous.
Ваш вклад лицензируется под свободной лицензией Creative Commons.
