Отремонтируйте ваше устройство
Обучение ремонту
Магазин
Помощь
Редактирование шага 2 —
Тип шага:
Перетащите чтобы изменить порядок
Lets get Started! You will find four tiny screws around the edge of the m:robe: One on either side of the screen, and two on the bottom. For these you will use the smaller screwdriver.
You may have noticed I have a screw loose! Or rather, missing altogether. These screws are tiny and very hard to find if dropped on the floor. Remove them low over a flat, clear work space and set them off to the side somewhere safe. They are all the same size so it doesn't matter if you mix them up.
Take note of the reset button on the bottom edge.
Ваш вклад лицензируется под свободной лицензией Creative Commons.
