Отремонтируйте ваше устройство
Обучение ремонту
Магазин
Помощь
Редактирование шага 15 —
Тип шага:
Перетащите чтобы изменить порядок
LG G Watch Repairability Score: 9 out of 10 (10 is easiest to repair)
Screws and spring contacts mean the rear case is super easy to remove.
The battery is held in with a single Phillips screw and minimal adhesive, making replacement easy.
Not the easiest watch band to remove, but an old standard that shouldn't pose much of a threat to band-replacers.
Clean design with few fragile cables and connectors means a more robust, repair-ready device.
A fused display assembly, glued into the front of the device, makes screen replacement a little difficult and costly.
Ваш вклад лицензируется под свободной лицензией Creative Commons.
