Отремонтируйте ваше устройство
Обучение ремонту
Магазин
Помощь
Редактирование шага 19 —
Тип шага:
Перетащите чтобы изменить порядок
you do the same thing at the other side.
if you remove, or going to remove the screen, be carefull with the cables, most of them are taped to the case or screen.
At the second picture you see the wires after removing the plastic grey cap. if you have problems with screen failure ( like a black screen or bad connection) its best to check this cable first before buying a new one. The wires are sliding to the cap and sometimes they get cut.
Ваш вклад лицензируется под свободной лицензией Creative Commons.
