Отремонтируйте ваше устройство
Обучение ремонту
Магазин
Помощь
Редактирование шага 3 —
Тип шага:
Перетащите чтобы изменить порядок
After lifting off the bottom, the PCB is exposed, and you can lift it out of the charger block along with the battery contacts. On the PCB we find:
A diode to protect against reverse current.
An LED and resistor that is on so long as the box gets power.
A giant 10 Ohm resistor to slightly current-limit the charge, and across which the green led and resistor are placed -- this will therefore light up as long as significant current passes to the battery.
Ваш вклад лицензируется под свободной лицензией Creative Commons.
