Помощь
Редактирование шага 6 —
Тип шага:
Перетащите чтобы изменить порядок
Based on the previous side, I assumed that disassembly of the 3.5mm jack side (to be referred to as "jack side" from this point) would be similar. I started by removing the surrounding ring, only to find out that there was no screws hidden underneath.
From my memory, there is absolutely no reason to remove this surrounding ring on the jack side.
After prying for a while, I began to wonder if some type of plastic clips were holding the two sides together. Knowing the two sides were already held together with strong "rails", I decided to drill out the areas where these clips were believed to be located
Ваш вклад лицензируется под свободной лицензией Creative Commons.
