Отремонтируйте ваше устройство
Обучение ремонту
Магазин
Помощь
Редактирование шага 12 —
Тип шага:
Перетащите чтобы изменить порядок
All is done. You can disconnect other sub-units down a bit more, but it's pretty straightforward. If you have a faulty flash you probably need to replace this entire board unit.
Note the large capacitor connected to the flash. Be VERY careful around this, it can hold a large amount of charge which could discharge into you, if you touch the ends, or into other electronics it comes in touch with.
Thanks for reading. This is my very first teardown, and I admit not all the images are great, need to get used to one handed photo taking. Hope this helps someone. I'm guessing most digital camera's of this type will have similar components!
Ваш вклад лицензируется под свободной лицензией Creative Commons.
