Помощь
Редактирование шага 8 —
Тип шага:
Перетащите чтобы изменить порядок
This Withings Activité Pop Smartwatch had water ingress and it failed due to corrosion. A common fault with this watch is loose inner screws, leading to poor PCB contact with motors. When you change battery make sure you apply silicone grease on the rubber gasket of the case back. The dial and hands are not accessible since the glass is pressed.
Ваш вклад лицензируется под свободной лицензией Creative Commons.
