Отремонтируйте ваше устройство
Обучение ремонту
Магазин
Помощь
Редактирование шага 10 —
Тип шага:
Перетащите чтобы изменить порядок
The 5th-Generation iPad earns a 2 out of 10 on our repairability scale (10 is the easiest to repair):
The LCD is easy to remove once the front panel is separated from the iPad.
The battery is not soldered to the logic board. We'll give it that.
Just like in previous iPads, the front panel is glued to the rest of the device, greatly increasing the chances of cracking the glass during a repair.
Gobs of adhesive hold everything in place. As with its Air 1 predecessor, this ranks among the most difficult battery removal procedures we've seen in an iPad.
The LCD has foam sticky tape adhering it to the front panel, increasing chances of it being shattered during disassembly.
You can't access the front panel's connector until you remove the LCD.
Ваш вклад лицензируется под свободной лицензией Creative Commons.
