Инструменты для этого Разбора
Введение
We disassembled this iPod on September 10, 2008.
The new iPod Touch comes in a smaller, transparent plastic case.
Someone asked if we should turn it on, or check out the new software before we took it apart. But we're just a little too eager for that.
The bare LCD display.
Apple gives the size as 3.5 inches (diagonal) with a 480x320 pixel resolution at 163 pixels per inch.
There are no screws securing the LCD. Instead, it's held in place with a little double-sided tape.
Removing the metal backing.
The battery is held to the backing with two strips of light adhesive, but peels off easily.
Disconnecting the display data cable.
Note the residue from the glue holding the battery to the metal backing.
This is getting exciting!
Removing the battery.
The WiFi antenna and circuitry are at the bottom of the image, near the thumb.
The large orange cable connects the WiFi antenna (upper left) to the logic board.
At the top of the picture above the battery is a metal cover. Underneath the cover is a Broadcom BCM4325 Wi-Fi and Bluetooth chip. Yes, that's right, Bluetooth! Apple has said nothing of this publicly.
This particular bluetooth chipset supports BT2.1+EDR. No word yet on whether the one Apple included supports A2DP, which would enable stereo headphones.
Part numbers: BCM4325GKWBG CD0825 B76332 P40 SF
You can see the dock connector in the center and the headphone jack on the right.
The logic board.
We think the brown rectangle in the center is the speaker. It looks like the two wires in the orange ribbon cable on the right of it run to the new volume control dial.
The battery. 3.7 V Lithium-ion polymer, as expected. Apple part number 616-0404. No word yet on the mAh rating.
The logic board again, this time with (what we think is) the speaker removed.
The NAND flash memory is a Micron MLC chip: MT29F64G08TAAWP
The processor is an Apple-branded Samsung-manufactured ARM with SDRAM on the package, similar to the iPhone processor.
Комментариев: 2
Broke the screen.
probaly should of used a hair dryer
i need all the parts of ipod touch 2nd generation
