Введение
This is a teardown of an Ipod Touch 3rd Generation to take it apart and see it's different components.
Выберете то, что вам нужно
You will need:
1x PH00
1X Splicer
2X Plastic Opening Tools
1X Suction Cup
You can then remove the suction cup from the screen.
After that move the screen to the side.
Once you do that you have to separate the black square from the rest so you can fully remove the LCD Screen.
After, use the PH00 to remove more screws.
Then use the splicer to start removing the orange square shown.
Once you do that, you can remove the battery and ribbon cable and set it aside.
You are now down with the teardown. If you want to put it back together again just follow the same steps backwards.
This is at a moderate level, definitely not something you should try without a guide.
In conclusion, the teardown went well and we managed to understand most of the components in the device.
