Вики, созданная, благодаря помощи студентов
Эта вики выполнена отличной студенческой командой из нашей образовательной программы.
Screen is Black
The computer is on, but the screen won't display normally
Screen is too Dim
Use Fn+Left Arrow to turn the brightness up.
Broken Screen/Loose Connection
Use the serial port on the back right of the laptop to plug your computer into a working monitor. Make sure the other monitor is plugged in. Then turn both it, and your laptop on. If the display shows up on the other monitor, the issue is most likely with either your screen, or the connection to your screen. Link to the display replacement guide
Won’t Turn On
The computer won’t power on normally when the power button is pressed.
Dead Battery
Try plugging in the computer before you turn it on.
Bad Ram
Try removing each stick of RAM one at a time. Try to power on the computer with each stick of RAM individually.(Link to ram replacement guide)
If the laptop turns on with only one stick of RAM, the other stick of RAM is most likely the problem.
Won’t Charge
The laptop won’t charge when you plug it into an outlet.
Bad Outlet
Try plugging your laptop into a different outlet and see if it charges.
Charging Cable is Broken
If your computer won't charge at all, and your computer didn't warn you that your battery was getting old, the problem might be your charging cable.
Bad Battery
Batteries get old and eventually stop working. If your computer has warned you that your battery was getting old, you may have to replace your it.
Keyboard Won’t Function Properly
Some or all of the keys are unresponsive.
Sticky Keys is On
Turn off sticky keys by hitting shift 5 times. When the message box pops up, select 'no'
Dirty Keyboard
Everyone's keyboard collects dirt eventually. Sometimes debris in your keyboard can interfere with functionality. Try cleaning your keyboard (not with water).
Loose Connection
Use a guide to carefully remove the keyboard. Put it back carefully, making sure the ribbon cable is plugged in completely. If this doesn't fix the issue, you may need a new keyboard. (Link to the keyboard replacement guide)
Computer is overheating
The computer is overheating and it's not cooling
Air vents blocked
Try to identify where the heat is coming from. No air flow means no heat transfer, so figure out where the air vents are and try not to block it while the computer is running. Move your computer to a hard, flat surface where the air vent will not be blocked.
Dirty/ Broken Fan
An accumulation of dust in the vents and fan through the cooling channels can restrict the air flow. If you notice any caution messages about overheating your fan is probably not working properly or it is broken. Link to our fan replacement guide to replace your fan.
0 Комментариев
