Unit won't start
The battery is fully charged and when I try to use the drill it is not functioning at all.
Battery is dead
The battery might not be functioning anymore, if the battery doesn’t provide enough charge the drill will not be able to function. So you will want to replace the battery.
Connection problem
If the wiring connection between the battery and the chuck is lose or not connected properly then the drill won’t function. So you will want to check on the wiring connection to make sure nothing is lose.
Dirt buildup
If the drill has a lot of dirt or stuff that accumulated in the chuck it might be jamming the drill and clogging the rotation. Make sure you clean the residue inside the drill.
Jammed motor
If the motor is not functioning it might be because of multiple reasons. Some of the components might be broken, and you will want to replace these components. It might be because of loose connection; fix the wiring. Battery might be weak so the motor doesn’t function; change the battery. Follow our Motor Replacement Guide
Battery won't charge
No matter what I do the battery is not charging
Defective charger cable
The charger might not be charging properly, so check on the charger or just try a different charger.
Battery no longer effective
If the battery has reached its life span it will not be powerful enough to supply the charge the drill needs. It will be best to change and get a new battery.
Air temperature too hot or too cold
If the drill overheats because of over use then it is best to let it cool down and disconnect the battery and then use it again. If it’s too cold then change the environment where you are using the drill.
Charger isn’t plugged in
The charger might not be plugged in completely so not enough electricity is flowing to charge the battery, so make sure the charger is plugged in correctly.
Unit shuts off abruptly
While using the drill it just completely shuts off and doesn’t work anymore.
Battery pack is too hot
After long use the battery might overheat which would shut of the power provided the drill. So let the drill cool off and then use it again.
The battery is not charged
After long use the battery might run out of power because it wasn’t charged well enough. So make sure the battery is fully charged and functional.
The motor is blocked
The motor might get blocked or jammed because of some component that got broken or loose, or the grease might have dried out, so make sure you open the drill up and check for the motor components. You can use our Motor Replacement Guide.
The chuck is wedged
The gears in the chuck might wear down after long use or it might just be stuck, so you will want to see our Chuck Replacement Guide.
Noisy motor
The drill won’t turn on even after long hours of charging the battery
Broken components
Some components in the motor might be loose or broken completely, so you can follow up on how to do this using our Motor Replacement Guide.
Jammed motor
The motor might be jammed because of multiple reasons, the motor is weak and you will need to replace it. Some of the components in the motor is stuck and you can follow our Motor Replacement Guide.
Loose chuck
The chuck isn’t working as effectively as it used to. The gear gets stuck, it gets loose easily, and gets jammed wile using it…
Planet gear problem
If one of the gears is loose or broken, then that might cause the entire system to fail and the chuck will not operate effectively anymore. Get your tool kit ready because you’re going to need it for the Gear Replacement Guide.
Connection failure
If there is a connection problem from the battery, then the motor is not receiving any power to operate the chuck, so check on the connections.
Burnt Light
The light will not turn on while using the drill.
Connection failure
The connection from the battery to the light might be loose or disconnected. See our Light Replacement Guide.
Burnt light bulb
The light bulb might be burnt so you will want to change the bulb using our Light Replacement Guide
7 Comments
Hi, my black and decker machine, model ldx120 is not working..it looks like the power supply is there for the led but the motor won't respond..
t.kunsel.tanju - Ответить
Trigger is stuck.
Amy Reaves - Ответить
My LDK220 Type 1 20 volt drill’s trigger is stuck. Chuck works, everything was working, picked up drill and couldn’t press in trigger.
The red charging will not go off on my B&D cordless drill no matter how long i leave it on the charger & yes the white power light is off.
Mick H - Ответить
New Black and Decker 14.4 vilt battery won't charge. No red light, nothing. Is my power source insufficient? How to rectify?
Regina Garabedian - Ответить
