Does your Dyson Ball Animal vacuum cleaner’s brush bar no longer turn during use? Dyson Ball Animal vacuum cleaners are susceptible to a range of problems that can cause their brush bar to become stuck. Check the following causes to identify and solve the problem.
Clogged Brush Bar
If your vacuum’s brush bar is not turning, the bar may be clogged by hair and other debris. Ensure that the brush bar button, which is gray and located next to the power button, is turned on. If this is not the issue, then the brush bar itself may be damaged or stuck. Remove and check the brush bar for built-up debris using this Dyson Ball Animal Brushbar Replacement Guide.
Faulty Brush Bar Motor
If you have tried the above solution and your vacuum still refuses to pick up dust and debris, your vacuum’s motor may be at fault. If there are no obstructions in any of the hoses, unclip the hose from the body of the vacuum. If you cannot feel the air being sucked into this compartment, check the filter. Remove the vacuum’s dirt bin from the rest of its body. Put your hand over the filter component at the base of the bin and turn on the vacuum. If you can feel the air in the filter component, but not in the hose attachment in the rear of the vacuum body, the problem lies in the cyclone assembly. However, if you do not feel air coming from the filter, there is most likely a problem with the motor or fan. Check this Dyson support page for Dyson Ball Animal replacement parts. Then, use this video to learn how to replace the Dyson Ball Animal vacuum’s motor.
Questions other people have asked about this
- Why does my brush bar not spin?
- The brush isn’t spinning on the bottom
- I can’t push my vacuum on the carpet
9 Комментариев
dyson not clogged brush won`t turn
Shirley Davisson - Ответить
The bushing that holds the brush cracks. 10$ part
Mat Cat Hat Sat -
will not buy another dyson
There is also an issue of the brush bar not spinning due to lack of power, I replaced my brush bar with a new one which also did not spin. On disassembly of the unit and following the power, I found one of the power cables to the head had been pinched and severed, down by the wheel. Repair is done but putting it back together is a challenge be warned!
Biffa 773 - Ответить
I have a dyson dc25. The brush bar is not working. I have replaced the brush bar. Still no action. I have checked the switches and they appear to be working. The gray brush bar push button does not appear to be ok. Have you any suggestions ?
David Coupar - Ответить
