Does your Dyson DC58 handheld vacuum no longer turn on? Dyson DC58 vacuums are susceptible to a range of problems that could cause them to stop turning on. Check the following possible causes to identify and solve the problem.
Battery is Not Charged
If your Dyson vacuum refuses to turn on, its battery might not be charged. Charge the vacuum’s battery for at least two hours. After the battery is fully charged, power on the vacuum and try using it again.
Faulty Battery
If your Dyson vacuum no longer powers on even after it has been charged, the vacuum’s battery may be damaged. If the battery is damaged, it will no longer hold a charge and will need to be replaced. Use the Dyson DC58 Battery Replacement page for instructions on how to replace the vacuum’s battery.
Questions other people have asked about this
- Why won’t my vacuum power on even after charging?
- Battery is fully charged but the switch doesn't seem to work
0 Комментариев
