Вики, созданная, благодаря помощи студентов
Эта вики выполнена отличной студенческой командой из нашей образовательной программы.
Battery Will Not Charge
When you plug in your device, it does not charge.
Dysfunctional Vehicle Power Cable Fuse
The fuse in the vehicle power cable that provides power to the device may be dysfunctional.
Vehicle Is Not Turned On
Check to make sure your vehicle is turned on. The vehicle must be turned on in order for device to charge.
Vehicle Temperature Is Too Hot or Too Cold
The battery can only accept a charge between 32 degrees Fahrenheit and 113 degrees Fahrenheit.
If the battery still will not charge, it may be that the battery itself is no longer functional. To learn how to replace the battery, use our Garmin Nuvi 2595LMT Battery Replacement.
Device Will Not Connect to Computer (USB Mass Storage Mode)
Device cannot be detected when connected to a computer.
USB Readability
- Unplug USB cable from computer, plug it back in, and reconnect the device
- Turn device off then on again
- Make sure the USB cable is plugged directly into the computer and through a docking station or hub
- Plug the USB cable into an alternate USB port on the computer
GPS Mount Won’t Hold
When you place your GPS mount on the windshield of your vehicle, it falls off.
Unclean Surface
Check to make sure the windshield of where you place your mount is clean, dry, and dust-free for the suction to work. Re-adjust mount to surface.
Worn Out Mount
If you've had your Garmin Nuvi 2595LMT mount for a long time, it might be time to replace it. The mount is no longer able to support the weight of the device over long periods of time due to wear and tear. Use our Garmin Nuvi 2595LMT GPS Mount Replacement to replace your mount.
Maps on Device Cannot Be Found
When you search for a destination on your device, your maps cannot be found and displays the message No Detailed Maps Found That Support Routing or Can't Unlock Maps.
Mapping Files Error
- Clear the message “No Detailed Maps Found That Support Routing” either by pressing OK, back, or press and hold your finger on the message.
- If a message “Can’t Unlock Maps” is displayed, remove the memory card from the device and restart the device without it otherwise you will need to reinstall the maps on the memory card.
- Ensure the memory card in installed with a FAT32 file system. If the problem still persists, reinstall the maps on the device and ensure they are up to date.
Maps Won’t Install/Update
When you install your maps via the desktop application, the maps are not updated.
Slow Internet Connection Prevents Installation
Use a fast internet connection to ensure maps install correctly.
Garmin Express Requirements
Check to make sure your computer meets the minimum requirements for Garmin Express. If it does not, use a computer that meets the requirements.
VPN/Proxy or Firewall is Not Disabled
If your computer has security software enabled, it may be preventing the installation of maps to the device. Disable your VPN/proxy and restart the device. If the problem persists, disable your firewall for this application.
Internet Service Provider (ISP) Restrictions
Check if you have ISP restrictions. If so, there may be problems with your bandwidth or Internet Service Provider. Contact your ISP to verify that your your Internet service is not being restricted in a manner the prevents you from downloading your maps.
Connected to Wi Fi Prevents Installation
Use a hard lined internet connection to ensure correctly downloaded maps from the computer to your device.
Incorrect Location Settings
Change time, time zone, or date settings on your computer and restart the device by turning it off then back on again.
Using Garmin Lifetime Updater
If you are using Garmin Lifetime updater to install maps, use Garmin Map Update instead.
4 Комментариев
Sometimes my Garmin Nuvi 2595 LMT just freezes and I can't get it to unfreeze. When it does this none of the buttons work and I can't turn it off. Other times it will work just fine. I thought it was the battery but that wasn't the problem because I ordered a new battery and had the same problem. It has always worked just fine before all this started happening.
countryman_1954 - Ответить
Has a fuzzy screen
Andrew - Ответить
What do I do
Andrew - Ответить
There’s 2 common causes that I have seen: 1) the GTM25 charging unit had a badly made batch, & the outer braid of the charging cable (power return/ground) touched the red 5V power conductor, that was stripped too far back to expose the copper wire, making it intermittently short. That does NOT blow the fuse, as the standard 5V regulator chip in the part that goes in the lighter socket, is designed to check for shorts, so stops the 5V supply output electronically (the green LED goes out & the Garmin then won’t charge). FIX: cut open rubber part of the “traffic FM receiver” part (little slim black box), furthest away from USB plug end & insulate the bare copper wires so they don’ touch, cover repair in more electrical tape. 2) the USB socket inside the Garmin has broken solder contacts. These CAN be soldered back, but you need a really good low-voltage miniature soldering iron to do this, AND it will need the motherboard removed (it is a major strip-down).
Tony Davis - Ответить
