Вики, созданная, благодаря помощи студентов
Эта вики выполнена отличной студенческой командой из нашей образовательной программы.
No Audio or Audio is Crackling
Audio from the device is not working or sounds distorted.
Interference from other Electronic Devices
Try using the laptop in a different room, building, or even outside. If the noise does not occur in a different location, you might have an electrical interference issue.
BIOS is not updated
Update BIOS to the latest version. For exact details on how to update your BIOS, visit HP BIOS troubleshooting.
Chipset and Audio drivers are not up to date
Run HP Support Assistant to automatically update the chipset and audio drivers. If this does not work you can manually update the chipset and drivers by going to HP Customer Support - Software and Driver Downloads for chipset and HP Customer Support - Software and Driver Downloads for audio drivers
Device Will Not Power On Even When Plugged In
The device will not turn on or show any signs of power even when the charging cord is plugged in.
Faulty Battery
If the device doesn't power on at first, try removing the battery, then hold the power button for 15 seconds to dissipate static charge, then reinsert the battery. If the device still won't power on, consider replacing the battery.
Faulty Power Connector/Charger
Check the pins inside the power connector socket, and the charger. If either pin is bent, use a thin tool such as a toothpick to realign them. If the device still isn't charging, try a replacement charger. If this fails, replace the power connector.
Weak Wireless Connections
Wi-Fi and connections are weak or there is no connection
Drivers out of Date
Common problem could be that your wireless connection drivers are out of date. Go to HP's Self-Service Page, input your operating system, then select Driver-Network and install the updated drivers.
Faulty Wireless Connection Chip
If your drivers are up to date and connection is still weak or inaccessible, the wireless connection chip is faulty. Replace the wireless connection chip.
Blue Screen of Death
The laptop gives a Blue Screen Error and stops responding.
INVALID_SOFTWARE_INTERRUPT (Error Code 0x00000007)
The 0x00000007 error can be caused by damaged, deleted or invalid system files. The issue can be troubleshot by booting the laptop in Safe Mode, by holding F8 while restarting the system. Open the command prompt by typing “cmd” in the search bar from the Start Menu, and run the program as administrator. Entering the command “sfc /scannow” will scan the system for and replace damaged system files. Using “chkdsk c: /f” can find and repair system errors and bad disk sectors. After troubleshooting, restart your device to start Windows outside Safe Mode.
Laptop will not boot to login screen (Error Code 0xc000012a)
The 0xc000012a error will often be caused by damaged or invalid system files as well, though this error will most often come up after a system update, and logging in will not be possible. Power the laptop on and off three times. On the third bootup, it will boot into the Advanced Recovery Environment. Menu through “Troubleshoot” to “Advanced Options” to “Command Prompt.” With the command prompt open, enter the command “sfc /scannow” to scan the system for and replace damaged system files.
Device Won’t Boot to Windows
The device powers on but displays nothing. This is also usually accompanied by the power indicator and caps lock button blinking.
Faulty Power Supply
Check the power connector’s socket. If the central pin in the socket is bent, use a thin tool such as a toothpick to realign the pin. If the problem persists, consider replacing the power connector.
Corrupted BIOS
Before or while powering on the device, try holding Win + B or Win + V to access the BIOS updater.
Failing Hard Drive
While powering on the device, repeatedly press Esc to access the HP Startup Menu. From the menu, select “System Diagnostics” (F2), navigate to “Component Tests”, and select “Hard Drive.”
Один комментарий
مشكله الكيبورد المضي توقف
Amir Mohammed - Ответить
