Вики, созданная, благодаря помощи студентов
Эта вики выполнена отличной студенческой командой из нашей образовательной программы.
Keyboard not Responding
Your keys work intermittently or a section of your keyboard stops responding.
Needed Restart
Restarting your computer may fix any keyboard issues related to Windows. Do this before trying to find another potential cause.
Dirt under Keys
Remove dirt by:
- spraying compressed air under keys
- removing crumbs with the point of a knife
- taking out keys and cleaning with cotton swabs
Bad Connections
This can occur when the keyboard loses connection with the motherboard. Reconnect the keyboard by removing the outer casing of the laptop and finding the connections under the keyboard. These ribbon cables will need to be reconnected for your keyboard to work properly.
Defective Keyboard
Keys are not typing letters and numbers, instead are opening random windows and indenting. Replacement of the keyboard may be the best option.
Laptop will not Turn On
Laptop remains off after using the power button.
Battery is Drained
Plug charger into laptop (and power supply!). Press power button to turn laptop on
Hard Reset is Needed
Remove the battery and power supply and let the laptop sit for a minute. After reinserting battery and plugging in AC Adaptor, press the power button to turn laptop on.
Defective Battery
If the above options do not resolve the problem, replacing the battery is the next step.
Crackling Sound through Speaker
When playing sound through the on-device speakers, sound is distorted or crackling.
Interference from Audio Enhancements
Click on the speaker icon on the right side of the Taskbar and select “Mixer”. Select “Speakers” in the window that comes up. Open the Enhancements tab and disable all audio enhancements by checking the “Disable All Audio Enhancements” box. Click “Apply” then “Ok”.
Outdated Sound Card Drivers
Type “Updates” into the Windows search bar and click on “Windows Updates”. Then select “Check for Updates” to receive a list of possible updates and install all of the updates listed.
Search for “Device Manager” in the Windows search bar. Select “Device Manager”. Search for Sound Card on the device list, right click on it and select “Update Driver Software”. Follow on-screen installation directions.
Damaged or Faulty Speakers
If the above options fail to fix the problem, the speakers within the laptop will need to be replaced.
Laptop is Overheating
Your laptop is hotter than normal or your fan is constantly running. It also may randomly shut down or struggle to perform basic tasks.
Clogged air vents
Check all air vents which are on the sides of the laptop for dirt and blockages.
Fans not working properly
Make sure the fans are working properly by feeling the air vents for hot air blowing out. If you don’t feel any air coming out of the air vents or you don’t hear the fans running once your laptop has been under heavy use for an hour, the cooling fans might have connectivity issues or need replacement.
USB Port Not Working
When connecting a device through the USB port on the laptop, nothing happens or an error is displayed.
Needed Restart
This is a good place to start to see if it will self-correct after restarting.
Port Not Recognized by Laptop
Use the device manager to scan for hardware changes because it might now recognize the USB device connected.
Faulty Motherboard
If the USB ports are not working, there could be damage to the motherboard or it is faulty. You will need to replace the motherboard.
3 Комментариев
touch screen problems
NANA KWADJO NKANSAH - Ответить
my hp pavilion x360 convertible laptop is charging only in sleep mode.when i connect the charger to laptop when am using its not charging.(plugged in, not charging) any one help me…….
Manikandan - Ответить
Power button is stuck. The laptop is in sleep mode. Not responding. How can I reboot without power button.
Col Santhosh Kumar - Ответить
